I am regretfully considering selling my 2019 Rickter Edge FS after some life related issues have occurred and am getting out of the sport 100%. (I am not looking to ship or trade anything and I am not desperate to sell)
Price: $26,500 - This was a 6 month special order from Blowsion and RRP
Build Thread: http://www.x-h2o.com/index.php?threads/2019-rickter-edge-fs-build.193256/#post-2011295
Nothing has been spared on this build: I have put near $30K just into parts to build this ski, nothing was spared. It is professionally built and 100% ready to ride. This ski is absolutely amazing; it can rip the lake, barrel roll and flip and has only been ridden for 2 months.
Hull is, and is registered as registered as a 2019 Rickter Edge FS. Dominator Front sponsons installed at the factory. Factory decals were installed over the sponsons and clear coated at the factory giving it that extra clean look. Sponsons are a must for this hull. Extra thick padding under the turf, Heal Kicker, Ninja Footholds with custom Heel Wedges. Thrust Scupper Ball valve installed.
I can negotiate include extra impeller, gaskets, jets, reeds, stand, Spare Lithium battery, Lithium Battery charger, hoses, couplers, life jackets, wetsuit, helmet, gloves, gas tanks, the list is huge and we can discuss in detail.
Also Selling:
Kawasaki Ultra 150 Jetski - Original Owner, garage kept all stock except for a Solas Impeller and Shreadmaster Ride Plate Intake Grate. This Ski RIPs will read close to 70 mph on the GPS. - $3200
Triton Trailer – 2 Place Aluminum Trailer with Brand new rims, radial tires and bearings. Rails and Carpet replaced at the beginning of this season. Includes spare tire,gas tank mount, and Cargo box - $1500 ( I will not consider selling the trailer until the Ultra 150 is sold)
- TPE 1021 Engine with PHP lightweight crank and OEM koyo bearings. Runs on 91 octane
- Full Spectrum 48 MM Carbs, Boyesen Intake Manifold system with RAD Valves, Blowsion FAs
- TNT V2Pro Pipe - water injection, TNT Exhaust manifold (ported and polished to match TPE exhaust Porting), RRP Waterbox, Limited Slip 3.3 Gallon Tank (plenty big to cruise the lake)
- NEW OEM start stop switch, lightweight lithium battery (~2lbs), NEW MSD Enhancer with RAD Lightweight Flywheel with OEM Hub, NEW Jetski Solutions ignition Coil, battery cables, and stator rebuilt wiring harness quick release system Installed. Newly rebuilt OEM starter (everything is done right to avoid any electrical gremlins so you can just ride)
- RRP Lighweight Pole with carbon tubes, RRP Lightweight OVP steering, RRP Ninja Pad, Blowsion Finger Throttle, Xscream Trim system, Blowsion Heavy duty Steering cable, Blowsion Hood straps/pole limiting rope
- H2o Designs 148 mm torrent Pump with Xscream Trim system, RRP Untrimmed intake grate, RRP medium Ride plate
Also Selling:
