Dasa 1100cc
10mm stroker
48mm Full Spectrum carbs
VForce 3 reeds
Power Factor Pipe
MSD total loss ignition
Thrust lightweight flywheel
155mm Skat Mag pump
9/16 Skat prop
Team XS nozzles
RRP CBX lightweight carbon poles
RRP fat bars
RRP trim lever
Thrust finger throttle
RRP steering
Thrust start/stop switch
Rad Dudes 4 gallon tank
Anti Gravity 16 cell lithium ion battery
RRP motor mounts
JetManiac mid shaft
Hull is a 2018 XFR with ninja foot holds, short ride plate, and removable sponsons. Hull has a few scratches on the bottom. Very low hours on everything. Motor was completely rebuilt this year with new sleeves, pistons, rebuilt crank, domes, reeds, cleaned and adjusted carbs, new motor mounts, rebuilt mid shaft, pump got a new housing and bearings, new rad dudes tank and battery. Only a few hours of ride time on this new setup. I don’t have much time to ride anymore and I’d like to get out of freestyle jet skiing. Ski runs amazing and is extremely powerful. I have the signed title from previous owner. Registered as a 2018 Rickter XFR.
$23,000
845 807 1562 - location NY
10mm stroker
VForce 3 reeds
Power Factor Pipe
155mm Skat Mag pump
9/16 Skat prop
Team XS nozzles
RRP fat bars
RRP trim lever
RRP steering
RRP motor mounts
JetManiac mid shaft
$23,000
