Build is one year old and only weighs 224lbs! Some parts are brand new!
- Dasa ninja 900 (same motor that got me a second place finish in pro freestyle at WF)! Only 17 hours on motor!!!
- skat-trak custom short pump (one of a kind! Allows for faster rotation)
- 48 modified mikuni carbs
- your choice of Tnt pipe (mid/top power) or rrp pipe (bottom/mid power) with RRP water box and RRP manifold
- MSD TL ignition on textreme mounting plate with lightened flywheel.
- Lightweight RRP handle pole with carbon fiber tubes, RRP straight bars, and RRP (new generation) steering system.
- ballistic modified battery (will hold up for more than 2 Years!)
- RRP rear tank, throttle lever, trim lever and hood latch
- RRP trim system (smoothest trim I ever felt)
-Carbon Fiber ride plate
- textreme chin pad
- Custom Carbon Fiber water manifold (cannot purchase anywhere).
- custom shortened steering and trim cable for weight savings
- some titanium hardware included! (Minimum $500 value)
- some parts not mentioned but everything on this build is top of the line with no corners cut!
*note
I like to disclose everything to buyer! The Tray started to split at rear after 5 hours of riding due to factory error but was repaired and will not be an issue.
Will provide more pics and info if you are interested.
*Buyer pays for shipping.
Text 760-805-4281 for more info.
- textreme chin pad
*note
