2016 Rickter XFR
Changing things up a bit. New TPE engine with very few hours. Everything is very solid and built to last with new components and a very reliable ready to ride setup.
2018-05-25 12.52.31.jpg2018-05-25 12.52.35.jpg2018-05-25 12.52.44.jpg2018-05-25 12.52.54.jpg2018-05-25 12.53.01.jpg2018-05-25 12.54.01.jpg2018-05-25 12.54.16.jpg2018-05-25 12.54.22.jpg2018-05-25 12.54.25.jpg2018-05-25 12.54.30.jpg
Please contact for more information, detailed breakdown of every component available. I'd be happy to keep the drivetrain and just sell the hull but it's all together ready to rip.
Two options:
Full Ready to Rip $19,500
Hull (as you'd get it from RRP) with medium ride plate, 155mm pump shoe installed, and matching RRP chinpad: $5700
Shipping is easy and I've got the original box still.
2016 Rickter Fiberglass XFR hull
Lightweight billet aluminum RRP pole
RRP steering stop
Ninja RRP carbon pole pad
RRP Breather tubes
RRP steering - Black billet
OEM Stainless pole bolt and nut
RRP Billet pole spacer
RRP intake grate
155mm RRP aluminum pump shoe installed.
Short RRP carbon ride plate
Rear sponsons included with the XFR
Ninja footholds
RRP Rear gas tank 1.5 gallon
OEM hood latch with RRP adjustable billet latch
Cold Fusion billet hood hooks
Billet bilge outlet fitting, 2 45 degree billet bypass fittings
Xscream 2 gallon jazz tank, P&P built
TPE 964 with new design billet head (new)
Jetmaniac aluminum flywheel cover
PHP Manifold
Vforce 3 reeds
Dual 46mm Mikuni carbs
ADA Throttle wheel
Tau Ceti flame arrestors
RRP Pipe with RRP waterbox - Used with 1 season on it
Midshaft housing, bearings, shaft, oem hardware
Able billet 3 finger couplers + rubber
Engine mounts + boltsEngine bedplates
Skat 155 setback mag 12 vein 9/16 impellerCut back impeller
Exhaust tube - cut OEMCold Fusion e box mount
155 pump to pump shoe seal
RRP Trim with cable and RRP trim lever
OEM pump to hull bolts - cut down
MSD enhancer
OCD Battery cables
OCD refurb coil with MSD Boots and sleeved wires
62T Lightened Flywheel
62T Stator
The rest of the ebox
OEM Fuel lines
10 ftKinetik APP14L Lithium battery
2006 Steering cable
Jetmaniac big throttle cable
RRP Throttle lever
New OEM Start Stop switch
AST Steering pad
ODI Troy Lee grips
RRP straight fat bars
Nice used starter and bendix
