2014 krash predator xs1000
One of the first preds built. Was made in Australia. Has legit registration as a Krash Predator. I recently moved from Chicago to Henderson Nevada, ski is in Henderson. Not a lot of hours on it, and has only been ridden in fresh water. A lot of the Michigan crew has ridden this ski and they will tell you it’s well built and has a ton of power. Original turf, no fading or stress cracks anywhere. It runs perfect and has been very reliable. This is a bulletproof surf ski.
Tricky built XS1000 first bore. Pump domes
148 torrent setback pump, bored nozzle. HD driveshaft from Jetmaniac.
14/19 impros prop
Worx intake grate
Xscream mod 46 carbs boyeson intake
Mint b pipe
Zero lightened and drilled flywheel.
Billet flywheel cover
H20 designs water box
H20 designs battery box
Jss ebox
msd enhancer
New extra ride plate
ATP Gold and black billet pole, steering, throttle
Bar mounted bilge switch
New odi grips
Cold fusion mid shaft housing
Cold fusion motor mounts
Cold fusion hood hooks
New oem gas tank. Oem fuel lines from Jetmaniac
Rrp riser bars
Everything else in excellent condition. It needs nothing.
$12,250
My cell is 708 476 2377
Addl pics
Awesome Predator man! Would love to have that set-up in my ski !
I ride mine also on lakes or rivers and absolutely love it!
Hope you sell it quickly!
