- boston
2014 Full Visual Carbon FS2 Evo
701 61x bore and ported by Nuklear with pro x pistons.
61x cases with SBT crank
B Pipe Limited
New ADA head with 34cc domes
Wet Jet intake with 46mm Carb
Mint electronics with everything OCD solutions makes and MSD enhancer
Zero drilled and lightened flywheel
Brand new black Limited slip tank
New cables
RRP billet light weight pole
New turf with custom modified ninja holds
Dakine single surf stance strap
Thrust ball bearing steering
RRP straight bars
155 OEM pump with dialed in prob and bore nozzle
RRP scoop grate
Jet dynamics shoe install by Brapp Dr
X metal water box
$10,000 season is here
call or text 978 771 5439
B Pipe Limited
New cables
RRP straight bars
RRP scoop grate
X metal water box
