2012 sj nozzle mod ???
OK guys when moving the steering cable closer to the nozzle do I have to cut away some of its supports?? And I noticed that my pump has a factory trim its just locked into place by a tiny bracket.. and I get a cable and remove the bracket and utilize it??
Well I figure. With a stopping plate and a spring to hold nozzle level and allow up movement only thru a trim lever and cable
Big Kahuna
Administrator
Tuscaloosa, AL
You can move the Steering ball inward to increase turning speed......... The Trim Adjustment bar has nothing to do with steering. You can get a cable and rig up a trim system....
2008+ SJ Stock Turn Plate and Steering Nozzle Quick Steer Mod
Tools needed
1. M6 x 1.0 Tap
2. 5mm Drill
3. Dremel Tool & Dremel Cutter I used Dremel high speed cutter #196
4. File to clean up the support rib on the steering nozzle
Step one pop of your chin pad and remove the steering cable and the ball joint. The ball joint on the turn plate and the steering nozzle are both M6 x 1.0 threads.
Step two drill the outside cast hole in the turn plate with the 5mm drill and tap. Apply blue thread lock and reassemble the turn plate ball joint and re-install the steering cable. Turn plate mod done.
Step three remove the ride plate and steering cable. The steering cable nozzle ball joint has a 5mm hex slot in the ball end to remove it from the brass insert pressed into the steering nozzle. Remove the steering nozzle.
Step four use the dremel tool and the file to remove the excess material from the top and bottom rib of the steering arm from the steering nozzle to allow drilling and taping of the new ball joint mounting hole closer to the centerline of the steering nozzle.
Step five use the washer from the steering nozzle ball joint to mark where the new hole for the ball joint will be drilled. Once marked use the 5mm drill and 6 x1.0 tap to drill & tap the new hole.
Step six re-install the steering nozzle use thread lock.
Step seven check and center the steering alignment (bars centered nozzle straight) I was able to get things straight with only adjusting the nozzle end.
Step eight Install the steering cable using blue thread lock install the ride plate use blue thread lock.
Step nine make sure you are not bottoming out your steering cable or it will break over time and use. You should be able to easily remove the steering cable from the ball joint on the turn plate with the bars hitting the stop block and pressure applied to the bars.
Step ten see how this changes things. You will smile:)
View attachment 254551 View attachment 254552 View attachment 254553 View attachment 254554 View attachment 254555
index.php
index.php
index.php
index.php
index.php
index.php
index.php
just go by a cable from earlier year that is longer more throw faster turns but it cost more! but then u have it for when u upgrade stearing systeme
JGringo
When in doubt, Throttle-out.
Stick with an X-Metal steering system on the handlepole. Infinite adjustment without fighting the nozzle. I wanted the same thing and just picked up their complete turn-plate and bars...
Well I'll probably do the nozzle mod Friday cause that is when my blowsion freestyle ride plate and stubbie cone and worx 228 intake grate come in...and thanks for the how to's
Oh quick question on changing pump cone ...do I have to remove the reduction nozzle or will the cones go thru it?
Thanks and I got it on their today along. With the new intake grate and Blowison composite ride plate!! Can't wait to take it out and see if theirs any difference!!
Finished product.. did the nozzle mod too but don't have pictures
I have a 2011 Superjet, what year cable should I buy 2007, see Pic. How will this improve the steering? Do I need any aditional parts to install?
