Other 2008 Polaris Ranger question
Ok quick question to you engine guys.
My family has a 2008 Polaris Ranger Crew UTV and lately were having some issues.
When we were riding it today it unexpectedly stalled out after I took my foot off the accelerator. We just got it back from a check up and we had the transmission fluid change, oil change, and new spark plugs. I check the air intake no blockage, Checked the exhaust no blockage.
Any suggestion or ideas to why this is happening
Here is a list of what the mechanic did:
Check/adj tire pressure
checked/adj idle
change oil and filter
check, service or replace air filter
clean battery posts
check steering
check/adj brake and clutch
examine for loose bolts and nuts
check hoses for cracks and leaks
change shaft oil or adj, clean, lube chain
grease fittings
check/adj choke
check instruments
test drive
Thanks guys
I know this is a jet ski forum I just don't want to learn a new site lol =)
Check the vent hoses for the carburetor and for the fuel tank, also check the fuel filter.Anything that would obstruct fuel flow.
SUPERJET-113
GASKETS FOR CHAMP BRAP!
These are fuel injected, but yes check your fuel filters and disconnect it from the throttle body and turn on the key and see if it pumps gas. Also there is a fuel filter in the bottom of the fuel pump in the gas tank under the passenger seat. Its easy to get to with 6 screws.
Sorry you are right about the fuel injection, I have a large problem around here with dirtdaubers, they love to plug up carb vent lines and gas tank vents.Just giving the guy something to check.
