long beach local
long beach local
- Az
I bet if you posted some pictures of the pistons especially the tops it would be easier for the gurus to diagnose. Its hard to believe the 61x is such a reliable motor it should run WFO all day long as long as its put together right. Are you sure no water is leaking in? it will cause the motor to seize and looking at the top of piston will tell you. At 4000ft elev. detonation and jetting dosnt sound like your problem nor lubication. I run the cheapest 2stroke oil I can find never had a problem and I`m old.
