I'm hoping someone has some ideas for the issues I am experiencing. It starts up fine, and runs fine for about 2 minutes. It then begins to run at reduced power (maybe 40ish percent power) with no change in speed when full throttle. The engine noise sounds like it normally would at 40 percent power. Within a minute of this it will kill. It starts up fine right away, but it's back to limited power within 20 seconds and then kills in under a minute. You can keep repeating this cycle.
The engine does not seem to be getting too hot, and the pisser appears to be passing water normally.
Things we tried:
-New spark splugs
-New fuel filter
-Ran with air filter removed
-Ran with gas cap removed
-Disconnected gas container vent hose (let remaining 6 inch hose cent directly to air)
-Emptied gas tank and refilled with fresh gas/oil mixture
I plan on running some carb cleaner directly though carburetor. Does anyone have any ideas beyond that?
Thanks in advance!
Things we tried:
-New spark splugs
-New fuel filter
Thanks in advance!
