- Lake of the Ozarks
Hello all. I am having some issues that I can't figure out.
The problem I'm having is after my ski is started, it idle's just fine. When i go to give it gas, I hear the engine revving up, but the impeller is not spinning any faster than when its just idling. Every once in a while, it will go past idle when i give it gas, It will continue normal for about 5-10 seconds before the engine just rev's again and the impeller goes back to idle, even though the engine is still revving high.
I have taken the pump/driveshaft out. The splines and the drive shaft are just fine and the impeller is not stripped. I'm guessing this is something stripped inside the engine?
Any help or guidance would be greatly appreciated!! Thanks!
