- Sequoia National Forest
I picked up a 1990 650 Super Jet on Wed. Took it to the lake last night and it ran like a champ. Clean ski with a rebuilt motor (exchange thru SBT) 2 seasons ago, dual cooling, added bilge. I did 2 short loops, maybe 15 minutes each, flopped over on it's side (just to cool off) at the end of each loop, but other than that it wasn't submerged. I did not run the aux bilge pump as I wanted to get a base line. When I got home I noticed more water than expected in the hull, pumped a bit out with the bilge to make sure it was working well, and then vacuumed out what I would estimate to be about a gallon. I noticed on the back of the hood (toward the rider) the lip of the seal seems to be folded over a bit (1.5" section) on each side . . . trying to stretch it back out with a wedge, clamp and some heat, but seemed like a lot of water to squeeze thru there. Checked the lines and everything seems to be connected and tight (I did notice the flush hose had come off the nipple, but I reattached before the lake . . . also for some reason the end of the flush is male so I have to buy a female o female hose fitting to connect it . . . seems weird they wouldn't just use a female fitting). I've heard the hoods on these years are notorious for leaking but wanted to get thoughts on other things I should check, other than the position of the bilge pump switch!!!
