1986 550 hull seperation bond rail splitting
Myself
manic mechanic
Twin Lakes AR
Last year my swapped '86 550 hull started taking on water. I found the rail splitting from the rear corners up to about the front of the tray. Apparently, this is a relatively common issue on the '86 hull. Here you can plainly see the seperation.
Myself
manic mechanic
Twin Lakes AR
I figured if I could get some epoxy in there it would be an easy fix. First I slipped in these small pry bars and slid them back and forth making sure anything loose would be 'open'.
Myself
manic mechanic
Twin Lakes AR
I sanded the edge of a paint paddle and cut it up making these little wedges. Then I just shoved them in about every 8 inches.
Myself
manic mechanic
Twin Lakes AR
Next I doubled over a piece of 60 grit to get inside and sand a bit. The oem greenish glue sanded out easily.
Myself
manic mechanic
Twin Lakes AR
I mixed up some epoxy with Cabosil thickener and added a bit of green pigment.....mostly to make it easier to see so I didn't miss anything.
Myself
manic mechanic
Twin Lakes AR
Then I just started shoving , and working it into the open gap. Once that was filled in I removed one wooden wedge at a time and used the tongue depresser to slide some epoxy up in those spots too.
Myself
manic mechanic
Twin Lakes AR
Then add some clamps and let it cure out........done!
Myself
manic mechanic
Twin Lakes AR
I did not. With the thickened epoxy and the split opened up, you can push/mash the epoxy right up in there. I smeared it up in there first with the tongue depresser. Then with a gloved finger just push it in like your packing a bearing with grease.
