300/440/550 1983 Kawi 550 broken starter?
My 1983 Kawi 550 has run great all summer. Recently I went to start it and all I get is a small click. The engine does not crank at all. At first I thought it was the battery so I tried to jump it but that was no help. Then I charged the battery and still nothing more than a click. Any suggestions on what I should do next?
screaming440
The Old Skool Professor
this problem is the battery, wiring, solenoid, or starter.
if you know the battery is good do a voltage 1) and voltage drop 2) test.
1) with a dvom put the +lead on the starter post and - on ground have some one it the start botton and you should read battery voltage. if you do not get battery voltage here you have a wiring problem or a bad solenoid.
2)with a dvom put the -lead on batery + and the + lead on the starter wire post.
have someone hit the start botton long enough to get a voltage. it should read less than .5 volts. if it reads higher than that you have a wiring problem or a bad solenoid.
if both 1) and 2) test good your starter is bad.
