- prescott arizona
Selling my mag pump I got from freedom racing. It's a superjet based 164mm 16 vein setback mag with the bigger 83mm hub (most mags are 75mm) so even though it's a big pump, the surface area is similar to a 155 setup. It's a billet pump, lightweight. Will need new bearings (they are a little rough, but spin). After I bought this pump I took it to a local Fab shop to have another water fitting added, I don't think he used stainless rod when he welded it because the weld is showing a little rust, but it's just surface and cosmetic. Comes with a custom made skat prop, it's pitched at 8/12 right now and has a nick in the leading edge of the blades, but doesn't seem to effect performance. All the veins in the pump are perfect, no damage. The driveshaft is included too, it shows a little wear but still very useable. Accepts Yamaha 155 style nozzles
$1,500
$1,500
