Hello x members ,just trying to get some input and info out there on 155 mm pump tune selections .first of want to thank deftones 56/tricky1 for the pump ,props ( pun intended) .my current set up is a ss900 on its first 865 bore ,pump gas compression, total loss @30 deg. pfp (dry).now with a 155 set back and 6/13 prop .89mm nozzle with 91 turn nozzle .i just changed to the stubby cone and haven't got to try it yet ,do you think this smaller cone is a good or bad selection ? my thinking is trying to unload the pump in an effort to get it on the pipe just a tad earlier ? i did get to spend a short but sweet weekend on this pump with the med size cone ,in which it was added braaappp for sure ,but maybe not quite as ground breaking as i had expected. but this is on a smaller cc stock stroke motor . i think it works good ,but i am comparing it to my 144 that i had pretty well tuned dialed for my set up .in my opinion so far i think i might need to turn up the volume and install race gas domes to give it some added braapppp in an effort to push this larger pump,also don't get me wrong it is defiantly allot better, but i want optimum settings.smaller bore w/155 mm experienced input welcomed .
