- Brigantine, NJ
Clean looking setup...why the kawi tank though?
Since the 144mm pump is 1" larger overall in O.D., it will interfere with the ride plate if installed properly. (using the existing FX drive line angle, on a retrofit. the kawi pump has a smaller O.D. and doesn't have that issue).I having trouble getting my plate to fit when I did the yamaha 144 swap on mine, any tips?
That's what I ended up doing to have about 3/8" clearance, with a thick carbon plate.Id make a rideplate, or you have to cut a decent size hole in the ride plate.
What's the best way to go about making a plate?
That's exactly what I'm doing, grinding out the stock one to about 140 and I think it should work great.Crazy to see this old thread brought up again. Blitz is my old man, but sadly we lost him this past December. RIP.
The 2 fx-1's in this thread belong to my brother and I. We're the ones in the Daytona pics and my bro is in the video posted early in this thread.
Both skis originally had the stock 122mm pump shoe, I recently rebuilt my ski and swapped mine out with the 144 shoe. The skis ran great with the 122 shoe and the only reason I swapped mine out was because I got a free pump shoe and my ski was completely torn down already.
Would I do it again? Nope. While the ski definitely feels a little more powerful with the bigger pump shoe I don't think it was worth all the hours grinding and the fiberglass work on the pump tunnel. *also additional grinding to the rideate.
if I were to do it again I would just modify the 122 shoe to get the opening as large as possible and skip the fiberglass work and grinding.
