1200 Super Jet
RiverRat
Louisville, Ky
All we need is to button some things up and install the throttle cable bracket. Jeff sent us the bracket late last week and once that is here we should be in business.
Just curious, are these WDK exhaust systems wet or dry pipes and do they use water injection from an external controller or run off the jet pump, these exhaust systems confuse me with thier outlet dimensions.........
RiverRat
Louisville, Ky
The pipe that we have is the wet pipe version and just uses a #70 main jet to cool the coupler on the manifold and is restricted down from a 3/8 line to a 1/8 line at the stinger. The manifold is tapped for running a water injection set up if you want, but we wanted to keep things simple on this build.
