- illinois
So I've had issues with this ski since I've built it, it will flat out rip for around 30 mins then all of a sudden it will just bog and barely get up to speed but won't top out at all and it will only idle after a few mins of trying to just get up to speed. I thought I was having water issues but I should have solved that with a versa plug, bilge, filter skins. The first time the plugs were wet and had some white stuff around the edge. Yesterday it ran great then the same and the plugs were dry. Gas cap is good and tank vent holds pressure. It's a built motor ported bottom end ported top end head and sbn 46 carbs.
