1 More Time Guru's
uncleuno
X-h20KC
OKC OK
Ok last time we talked my ski was finally put together and I had a bad crank, and I was wondering if I should put a 750 in it.So got a new crank from a running 650 ski got my ski together took it to the lake and now it seems I have another bad crank. My ski will rev up out of the water but soon as it gets a load on it , it feels like the carb is loading up which is not happening.If I make the ski cavitate it will rev then it starts to bog down again. Im changing the nozzle tommorow cause the local guru said he had a race ski that had a nozzle that made the motor do the same thing.I am at whits end any clues whats up?
WFO Speedracer
Alabama
I seriously doubt its another bad crank,something else is up,need the info
uncleuno
X-h20KC
OKC OK
I know its not another crank I hope. Heres my ski ported cylinder,westcost head,jetsport pipe , dyna total loss, mikuni 44, and so on yes its still a 650.Prop is 15 straight cut.
shawn_NJ
Chasing waves.
Daytona Beach
Its not the nozzle. Sounds like your carb is off or you have an exhaust leak. I had the same problem last year....ski wuoldnt rev unless I hopped the pump out of water. Then it would rev out for a little while. It turned out to be the carb and an exhuast leak. Do you have the stock jetting in the carb? What carb?
uncleuno
X-h20KC
OKC OK
Ok maybe it is the carb but that would be too easy SHAWN NJ mine is doing the same thing what jetting should I have in it. I know its not the nozzle but my resident guru said try it.
WFO Speedracer
Alabama
This kind of sounds like what I have going on with my Dyna based Westcoast ignition,does it act like it is skipping or missing at all?:Eyecrazy: Also does it have an auto cutoff switch on that ignition?
shawn_NJ
Chasing waves.
Daytona Beach
I know I sound like a broken record. But really go over you exhaust. IT TAKES THE TINYEST SMALLEST leak, and it will do exactly what you are describing. I thought mine was good and replaced everything else (elec and carbs). I lost the entire summer last year chasing it down. The whole time it was a hairline crack in my FP headpipe that was leaking an almost invisible amount of exhaust into the motor compartment. Get it to rev out then ride it to shore. Quickly open the hood with some sun rays or a flashlight. Really make sure there is no smoke in there. I found it with a laser pen. That was the only way I could see the leak! No oil, nothing. Just a tiny bit of smoke. After I got that fixed it would rev, but not so good. So I put a brand new 46 on with:
120L
150H
2.3ns 95G
and its been flawless since. This was a 800 motor with 650 ignition.
Kaveman
Born in USA(not Kenya)
Pull the flame arrestor. Rev the engine and look for fuel coming up out of the carbureter. If you do have fuel coming up when you rev it then the reeds are suspect.
uncleuno
X-h20KC
OKC OK
I'll try everything mentioned . This thing has been a ordeal all summer I'm about ready to take my 50 CAL and put it out of my misery. Thanks for all the help .
Crab
thanks darin...noswad!
Seattle
Don't confuse that with spitback or reversion, a cloud of fuel you will see momentarily when you do that.
madscientist
chilling with these guys.
good old p'cola
crankcase drain block off leaking, crank seals, old oil injection nipple . all are potential leaks. and by ueing the oil nipple for a primer it can draw extra fuel and run rich as hell
uncleuno
X-h20KC
OKC OK
Crankscase and oil injection is blocked off and there is no primer on it I'm going to hit the lake later so I'll see how it goes.
WFO Speedracer
Alabama
See how it goes, what have you done to correct the problem?
