Мой новый мотор Украина
Привет всем.
Писать буду на русском, переводите сами, если интересно.
Готовлюсь к новому сезону.
Мой новый мотор:
Novi 48 карбюраторы
ADA +8 блок
Колонка Xmetal
Сам изготовил крепеж под колонку, коробку под аккумулятор, заливную горловину под бак, фильтр в бак, усилил корпус, крышку на колонку.
фото:
фото
фото
фото
фото, разширителей бортов
Усилен корпус, и вклеена трубка под трим
Изготовил сопло методом литья в песке по моделе Gp1200. Приварил ушки для кольца трима. Осталось изготовить кольцо под трим.
Swooperjet
Bring the brap!!
Dallas, TX
I wish I knew what that guy was talking about. Anyone got a translator?
U think he's coming to the LSFR??? :biggrin:
I think he said.....ajdjki(^GMGFrfj*jfjfkal^/hfasdj<.
Or something close to that.
:Eyecrazy:
Definately a nice looking motor and other parts though! Wish I understood too!
ger87410
How did I get here?
Fort Worth
He's typed in english before.
I think he's giving us details of a build.
Either that, or some new top secret way of getting your skis to jump higher.:popworm:
J
justride
Guest
That's funny!
Here is what he said in English
Greetings to all, i am writing this in russian, you can translate it for yourself. i am prepared for the upcoming season. my new motor has novi 48 carbs, ADA 8mm stroker, xmetal pole, shaved tank filler housing, reinforced hull
Привет всем.
Мой новый мотор:
Novi 48 карбюраторы
ADA +8 блок
Колонка Xmetal
фото:
translates to:
My new motor the Ukraine
Regards by all.
Write I will be in the Russian, you transfer themselves, if it is interesting.
I am prepared for the new season.
My new motor:
Novi 48 the carburetors
Ada +8 the block
Column Of xmetal
Itself prepared fastening under the column, box under the storage battery, filler neck under the tank, filter into the tank, strengthened housing, cover to the column.
the photo:
and....
Есть фото гидроциклов моих друзей, если интересно могу выложить.
is.....
There are photo of the hydro-cycles of my friends, if interestingly I can lay out.
Привет всем.
Мой новый мотор:
Novi 48 карбюраторы
ADA +8 блок
Колонка Xmetal
фото:
translates to:
Regards by all.
My new motor:
Ada +8 the block
Column Of xmetal
the photo:
and....
is.....
about a minute too late buddy
