- Rochester New York
Up for sale Black and Yellow 2016 Rickter xfr (Fresh Water ONLY Ski)
Fresh Carb and Fuel system Cleanout on August 28,2025 and Runs perfect !!!
This Ski is a lot of fun and I will miss it but I haven't had time for it. Please review the pics and read about the build and reach out if you’re a serious buyer. Hull is in good condition with some trailer bunk rash and a few nicks. Also because of the XFR hull layup this hull could be confidently ridden in the surf.
TPE 964 with less than 25 hrs on Complete rebuild. Motor is fogged so Serious Buyer only !!
Clean New York Paper work
TPE Billet Head
Lightened Fly wheel
Millenium Re-chromed Cylinder at Time of Rebuild
Compression checks @ 180 per side
Mikuni sbn 46mm Carbs with external remote fuel pump / New OEM throttle cable
Boyesen Reeds and Intake manifold with speed plate
RRP Straight Handle Bars
Riva Throttle Lever
RRP Billet Hand pole
RRP Hood latch
RRP Foot Adjustable Holds
RRP Sponsons
RRP Ride Plate
RRP Intake Grate
RRP water box
Torrent 148 setback with 13/21 Solas impeller
Thrust Easy pull trim with New Cable
Power factor pipe (Water jacket NOT cracked)
Manifold Spray Bar installed.
MSD ignition enhancer
9 Liter Cart Fuel Tank
Cold Fusion Hood Hinges
Antigravity AT12-Bs Battery with Re-Start Technology (2.3Lbs)
$ 15,500.00
paypal fees NOT Included in price
Shipping in the USA available at buyers’ expense
TPE Billet Head
Lightened Fly wheel
Riva Throttle Lever
RRP Hood latch
RRP Sponsons
RRP Ride Plate
RRP Intake Grate
RRP water box
$ 15,500.00
