- Sacramento Delta
I am installing a Factory Limited B-Pipe on my 1995 FX-1 with the single carb oem SBN 44 carb and stock 61x engine with the oem head. And currently a MSD enhancer, but may move to a Zeel charging CDI in the future.
The pump and the aluminum impeller are likely stock.
Do you recommend that I change the impeller?
And if so, to what impeller?
Low end grunt is what I am looking for.
Looks like oem stock aluminum to me:
