- North Idaho
Do you have a rough price in mind and Is this something we would be able to drop some money down to secure one? Don't want to miss this.ok well you wil be pleased to know we have been working hard on this and we are a few weeks away from an announcement. I do not expect this to be a big seller and i think its going to be a run of about 20 of them and then we will be done
Cannot waitWell yeah I have been working hard on this and it getting a lot closer. I have been busy with a lot of other parts. But recent events have me flat out on the pump again
I will announce it here first and no i don't have the price sorted yet, but In true wax racing style we will make it affordableDo you have a rough price in mind and Is this something we would be able to drop some money down to secure one? Don't want to miss this.
yes we are thinking along those lines. there is not much room under the tabs to hold a thread and this makes it trickyA new nozzle would probably increase the cost significantly. Nozzles get broken sometimes too so I'm not sure that's the way. Maybe some bolt on brackets that mount to the pump flange? Could probably have them cut from stainless and bent 90 pretty cheap.View attachment 455791
If it was easy, anyone could do it. With your capability, what if you made a universal 144 yamaha nozzle with the ability to bolt on different mounting tabs for different applications, i.e. Superjet or FX1 or even sold with no mounting tabs so billy jo bob redneck can make his own tabs to do a 144 pump swap into whatever backyard wavejammer project he's working on. Anything specifically FX1 is a low volume project, but being able to also use the nozzle in the Superjet or even other projects might bring costs down. Make sense?I’ve got a few ideas in my head for the rear setup, but I’m also keen to hear what you guys think. Would you prefer a completely new nozzle if it pushed the price up a bit? Or would you rather modify existing parts and keep the kit more affordable?
This is a beautiful idea. A interchangeable bracket made for different hulls. Selling that nozzle separately as a replacement part for whatever ski has a 144 pump witha hull specific bracket would be cool. Although being able to utilize any 144 nozzle would be nice. I'm curious as to how hard it would be to utilize the 4 bolts and the outer edges of the pump and build a bracket that basically lays around the outside edges of pump housing on the flat portion before it tapers towards the aft end. Even if you made the bracket 1/4 inch thick all the way around just sell 4 new bolts that accommodate length of the bracket added to the pump. Then just attach some metal to top side of pump to regular mounting ear point of specified vessel. I'm not sure if you can picture it basically same idea as above but not making a new nozzle just adding more length to pump by either adding a backet gets sandwiched between pump and nozzle or just layed behind nozzle that eventually makes it's way to mounting points on ski.
That's where we are heading to, the similar idea, It pushes the price up but somethings are what they are, It does mean we can have multiple different uses for the nozzle which is always a win. Nice drawing by the way
Just think about how many hours you’re saving people from doing a full conversion! This is so worth it, if not even for a performance gain but for the ability to use readily available parts VS practically nonexistent FX-1 pumps/seals/impellers. This idea is a win overall and I’m buying for sureIt pushes the price up but somethings are what they are
Listen give me a reason to get an fx1. Loved mine and my dad owned one new. If I can put his butt on one and blow his mind it would be worth every penny.That's where we are heading to, the similar idea, It pushes the price up but somethings are what they are, It does mean we can have multiple different uses for the nozzle which is always a win. Nice drawing by the way
Now I need to find an fx1OK Ok . Im hearing you loud and clear. Will design a new nozzle to go with it
