I started off with a stock SN hood, seems like i was getting too much water inside so i decided to do a quick mod to it and see if it helps. Over the winter i will remove the whole liner and do a much better job. Used marine epoxy, then silicone over that then some spray foam to make sure it seals up good. 1.5" hose on each side, blocked off the rear hole and left the front open
