Always use a timing light to KNOW what timing your running! You'll never learn to do high performance engine work if you don't know for sure. Too many variables in this business.
If you don't know how to do it just ask or do a search.
Use a sparkplug dial indicator, mount a pointer off the coupler cover boss, use piston height chart, mark the engine coupler at what degree you want, fire up ski hold about 3000 rpm's using a standard timing light.
Are you running a MSD Enhancer or stock cdi? The Enhancer will give you a little room to advance timing.
I have ran mine like this for a few seasons, fuel anywhere from 87-04 octane, msd enhancer. some WOT, but not much when Ive got a tank of cheap gas. Chuck is right KNOWING your actual timing is the best way, but if you are lazy, and sometimes lucky like me, you can just 'wing it'
I don't understand why you need to advance the stater if you are using an epic. The epic with the proper program should do the advancing for you. The curve was probably meant to used with the stater at the stock settings.
To answer your question I sort of remember that I figured out the amount of change at the diameter of the alignment marks to be 1.1 mm for every degree. I am not 100 percent sure because that was a long time ago. You should be able to print degree wheels from the internet and reduce or increase in size if needed to match the diameter of the alignment marks. Then all you need is a caliper to measure out your new alignment marks
I matched a degree wheel to my stator plate and marked off ticks for each degree between the 0 and the 5 degree mark. I'm planning on advancing 4 degrees and run an ATP Epic ignition with a lightened OEM flywheel. Is 5 too far? Reliability is paramount. My setup is the same as in an earlier post on this thread except for the ignition and new BJ 44's. Always run 93 octane at 50:1, but have been recently advised to mix AVgas 2:3 with 93 pump for improved performance. I like the idea of AVgas, but not the hassle of obtaining and storing.
