- Montreal, Canada
Hey all,
I posted this over on greenhulk, but haven't had any answers. I thought maybe some of you running a 701 with a pro-tec head could maybe clarify some issues for me:
I started putting all the goodies on today that I got over the winter (I know it's late in the season to be starting) and I ran into several issues. (PS: 1996 701 Raider, 61x engine.)
One, I snapped one of those dinky little screws that holds the reeds on the cage, now I have to find a small enough bolt out to remove it, plus find a new screw.
Two, I dropped one of the temp sensor screws in the hull and I'm pretty sure it went under the fuel tank..
..which I need to empty to switch over to 91 octane for the high compression head, but it's 3/4 full..
And the head has me scratching mine, because the spark plugs in the stock head have shorter threads than what the pro-tec rec head needs. I never really thought about the length of the threads; are there the same heat plugs but with different lengths?
Second question 'bout the head - the mounting holes don't line up for the stock exhaust bracket of the 61x, nor do they line up with the wet-jet exhaust I was hoping to run. Anyone have solutions for this? The reason I ask is because both exhausts are heavy (the stock one needs a bracket), especially the wet-jet one, and I'm scared that without support it would bang around. Heck, even attached I'm kinda worried it would rip off half a cylinder. I still have to check to see if the new pipe will fit, but I think it should.
On the bright side, I got the new F/A on and the jets in the carb without any trouble.
Also started working on removing the old mats, which came up pretty well, except for the glue. I haven't tried acetone yet, but I tried the Goo Gone automotive spray gel. Nothing! It made it less sticky but didn't remove anything. I really didn't try too hard, so I guess it merits another attempt tomorrow with the Goo. If that doesn't work, I'll break out the acetone.
As for the new Hydro-Turf, I'm surprised there's no cutout for either the HIN or the gay-spray. What do others do about it? I'm thinking for the HIN I can just use an exacto and make a little cutout, but for the spray, do I just cover over the hole, or do I cut a hole in the turf? I have no objection to having the spray there.
Thanks for the help, and hope you enjoyed the read.
Dave
Dave
