Video Capture Software?
ksmith83
( o Y o )
What Im trying to do is capture the video/game play from my playstation and save it on a hard drive. I was told that I would need and external hard drive, got that, and a form of software that would recognize the feed coming from the ps3 and I could record the game play. Does anyone have any suggestions?
ksmith83
( o Y o )
i did google and research and went with a dazzle recorder. Seems to be easy enough so far and a decent price when i have a sister that works at best buy. i was just seeing if anyone on here had a different opinion. thanks for yours.
ger87410
How did I get here?
Fort Worth
If you can't find a program that runs on the PS3 that will record for you, your ONLY option is to capture it using a tv tuner card.
If you want to capture using the hdmi, you have to get a card that will plug into a free ePCI slot, not just a regular PCI slot.
If you want to capture in true HD, you pretty much have to use the hdmi interface. Coax, composite, and s-video don't have the bandwidth for HD.
EDIT: Assuming you're going to use a computer. I think some DVIs can record video. There's also DVD recorders that will do it.
Dustin Mustangs
uʍop ǝpıs dn
Holland, MI
Yeah, those are basically your two options. Capture card will put a file directly on your hd or you can do it indirectly through a stand alone dvd recorder that has a/v inputs. The capture card would be less of a hassle and could also produce a hd file if you pick the right one and use the proper cables.
guiness92
as said before, use dazzle. I have it and you can record anything that you can plug into it. It has svideo inputs, rca inputs, hdmi inputs and a few others. It will play through your computer and you can rip anything in the world to your hard drive.
