- Lake Orion, Michigan
Both mine and Tru's ski's are done and have been on the water for some time now. I thought'd I would post my observations between the two setups plus thought others might enjoy the reading. All comments/questions welcome. I will for the most part keep this short and sweet. Before I go into more detail, here are the setups.
Roo's Yamaha setup:
Motor
Xscream 1000CC (90MM/78MM Stroke, 992CC) (~195 PSI Compression)
Full Spectrum 49MM carbs
Thrust billet airbox adaptors w/Yamaha stock airboxes
Boyseen intake system
Performance
Power Factor dry pipe
MSD Total Loss Ignition setup
Driveline
Skat Trak 145MM setback magnum pump (13/19 prop) (84.5 & 87MM reduction nozzles... more on that later)
Thrust Innovations Trim System
Hull
RRP Rickter FS-1 Fiberglass hull (113 lbs w/hood)
Worx WR228 intake grate
Tru's Kawasaki setup:
Motor
Kommander/Dasa 1000CC (89MM/78MM Stroke, 970CC) (~170 PSI Compression)
Kommander/Dasa Spacer Plate between cases/jugs
R&D intake manifold w/vForce3 reed system
Performance
Factory Pipe 800 SX-R Dry Pipe
Blowsion Programmable Ignition
Driveline
Skat Trak 145MM setback magnum pump (12/17 prop) (82.5MM reduction nozzle)
Hull
Trinity Composites SXR Pro Hull (86 lbs w/hood)
R & D intake grate (max loader? / 3 shovels)
Both ski's are setup for freestyle ONLY. We don't race, top end is of no interest to us.
The first time we had them both out, the Yamaha had a 84.5 reduction nozzle. The Yamaha setup BLEW the Kawasaki setup on bottom end - it was no comparison. The Kawasaki came on very strong in the mid range, but still not quite as much as the Yamaha. Overall, the Yamaha felt stronger everywhere.
The second time, we were out at our buddies house where they were working on dialing in the Kawasaki a little bit better. At this point, I found no reason to mess with the Yamaha - it is a perfect package out of the box and I just want to RIDE. They were able to pick up a bit more bottom end power after tigthening up the Power Valves and some carb adjustments, but the Yamaha still blew it away on the bottom end (and all around for that matter). That same day, the Yamaha's steering nozzle shattered and reduction nozzle started to show some cracking. I switched it out to a 87MM reduction nozzle and a 91MM Pro-Tec Aluminum quick turn nozzle. I felt I lost bottom end power and picked up some mid, but the bottom end still killed the Kawasaki. I will going back to a 84.5MM once it is repaired (might step it up to a 85MM actually and call it good). Overall - Yamaha still blows the Kawasaki away.
Next route to go for the Kawasaki is a bigger reduction nozzle (84MMish), and open up the stinger end of the dry pipe. Also, a new ignition is going to be used. I will have more input in the next couple weeks once these changes are made. These changes without a doubt will make an improvement, but I can't see them creating the low end the Yamaha does.
Carbs came jetted/setup by our engine builder(s) for those wondering. I do not have the exact specs at this time.
-Andrew
Roo's Yamaha setup:
Motor
Performance
Driveline
Hull
Motor
Performance
Driveline
Hull
-Andrew
