Copper gasket to seal or not to seal??
junkyardj
┌∩┐(◣_◢)┌∩┐
ive seen people use sealer on copper gaskets and ive always just heated them up with a torch before i install them
is there any real plus or need to use sealer?
dfw
Soft copper can flow around small dings in the surface but thats about all on a jetski engine. Make sure the surface is perfect and use some sealant.
SUPERTUNE
Race Gas Rules
Clearwater Fl.
Yes anneal the gasket, scrub with scotchbrite pad, wipe with thinner then 2 coats of coppercoat spray will work well in most applications, but not all, like a 650/701/760 when trying to use as a headgasket.
Works fine for a base gasket.
junkyardj
┌∩┐(◣_◢)┌∩┐
copper spray a gasket after annealing.improves sealing if marginal.
cool thanks fella's!! i ended up using the sealer and it was the base gasket
good to know for the future
