michael950
for me to POOP on!
- Houston, TX
I wanted my first experience with turf to be on something that would not matter if I roayally f'd up, so I turfed my scissor stands. Here is the write up:
Turfing Scissor Stands:
1) Materials Needed
Hydro-turf
Utility knife with a new blade
Coarse sandpaper (I used 60 grit)
Mineral spirits and a rag
Rubber Mallet
Adhesive: Hydro-turf Glue or Dap Weldwood contact cement
2" Disposable paint brush
Paint stirrer
Watch, timer, or beer
2) Cut Hydro-turf Strips
Begin by cutting your Hydro-turf into strips long enough to cover the tubes of your scissor stands. I used an extra shelving bracket as a template. The width was perfect (2 1/4") and it had an edge (lip) to push against to ensure a consistent width.
3) Prep stands for adhesive.
I used a coarse sandpaper of 60 grit to rough up stand surface. Cutting a piece if sandpaper into four 3" x 3" squares I used one square per bar. With the sandpaper, in a circular motion, I roughed up the surface in perpetration for the adhesive. I removed my stickers to reduce the chances of the turf peeling off.
1) Materials Needed
Hydro-turf
Rubber Mallet
Paint stirrer
