- New York Crew
I just bought a set of old 44mm blaster air cleaners and it got me thinking. We really dont have a great design or an alternative to old parts or buying OEM old designed parts.
If you run the 4 bolt topped mikunis your only option are the older OEM intakes. I hate the air horns on carbs, because you have to run race filters or the only good part avail for those are Brian's adapters,from Thrust Innovations. Great choice but what about with the 44mm or 46 mm carbs with the bolt tops.
The great thing about the air horns is they help with air flow into the carbs.
What I'm looking into, and currently designing is the 38mm carbs stock intake top with a new bottom plate that bolts to the top of the 4 bolt carbs. I will incorporate the air horns into the new bottom plate so it just bolts to the top of the carbs, like the normal 38's. Then the stock top bolts to it. Currently I'm designing around the Boyesen 44mm + sized manifold, shown below.
My question is, is the in line intake plastic box too restrictive for an application like this? The intake area is much larger than the single old blaster style.
It would also work with the new Wamiltons intake cover, or stocker
