Flash-FX
No Square..No Round..FX-1
- South Jersey Shore
I'm close to those same #'s. That last 10% is the tough part.I don't know I'm still at 90 %. If I ever get that last 10 % and find out I will post it here so everyone will tell me I'm wrong.
Here's a couple of pictures just to prove that I don't know what's going on yet...Who else would cut a hole in the side of a 2yr boat just to get at the carbs? LOL...Back before the cool 2 piece Boyesen and R&D dual manifolds, It would take a good hour+ to do a jet/pop-off change (duals) on the FX (there's no room in there, even with custom offset wrenches). I even welded a cable stop on the front of the manifold so the dual carbs could be run with the pump sides in. The pictures show the single 46mm setup, also spun around. I could do a jet change in about 10 min on the single.
The round patch is a cover where a Racepak II used to be before it turned into a aquarium. Before that died, It allowed me to dial in the top end perfect. You could set both carbs to run all day WOT @ 1150 or whatever degrees...and the sales guy told me it was waterproof....LOL...
The cold water seems to help make it run a little leaner (crisper).just to know for sure,I pulled the carbs off the stroker and put them on a ported 701 I have.At first they were still muddin along in 1/3 range,but I kept moving the pilot screw in adjusting the pop off slightly with bending the t bar.I forgot to bring a pop off guage with me,but I really smoothed out the 1/4 to 1/3 slow accel and cruise areas alot,I was close to getting it perfect
