- Brisbane Australia
I've got an issue that I thought was a blockage in the water box, turns out it's not.
It's a 701 SJ, 46mm BlackJack's, Riva Girdled head, R&D Wetpipe yadaya, motors (fresh.... a few times now
burnt out pistons lo).
What is happening it's failing to come onto the hi speed circuit (I think) of the carbys. Inturn trying to ride it sees the pipe get too hot (lean?)
Idles fine, blips and revs fine out of the water but on the water its OK (well how it's always been) on low throttle, open it up and exhaust noise changes to some sort of weird musical instrument and ski doesn't go anyway (well holds the same speed/decelerates a little).
However sometimes it just hits like a switch and comes on, either on occasion when hitting the throttle or sometimes where throttle is already in the area where it comes 'one pipe'.
Another test that proves its fuel related is if cruise around at low throttle and pump up the carb's using the primer I can hit WOT and it takes of sweet (haha).
I've rebuilt the carbs, and had them apart since then (Piston failure). I've blown through them with pressurised air hose. I can't see anything wrong. I've set the jetting and screws up as per Art's recommendations.
On thing I noticed is there was no little filter inside the carbs originally, I used the one in the kit but perhaps Blackjacks are not suppose to ? (in saying that it did 20hrs with the filters running fine).
I'm going to pull them off again, but I'm thinking maybe there is water trapped in them or something blocking the jets? (Fuel seems OK).
It's done this on occasion before, I then may have trailered it only the next day 1hr or something, put in the water and its sweet.
I really want to avoid doing another piston, I'm already likely going to have to hellicoil some exhaust threads and head too I've had this thing apart and together that much
Cheers for any advice
