Lou,
Do you need the entire cable assembly or just the wire rope. Last time I replaced mine all I needed was the wire rope, it cost me about $15 from Terry Cable.
O ok I see, you will have to measure every item thread pitch length etc. and let Terry Cable know what you have so they can make an exact replacement for that cable.
Or they may be able to just crimp a new end on that sheath for you, they will need to cut the end off the sheath and install a new one, your sheath should be plenty long to loose an inch in the process.
