re-foaming history
waterfreak
I had a vision!
s florida
i recently found out when i was putting my ski back together that my trim tube wasnt sealed good so it had been leaking water in for who knows how long.if i keep my hull next winter i gotta re-foam,im dreading it.
It's a losing battle trying to keep the tray dry. This ski was taking in water from numerous places:
-improperly sealed scuppers
-bondline
-exhaust outlet
-trim tube/cable
-driveshaft tube (from pump to firewall)
- several holes on the top gunwale and tray
-huge crack in the left foothold
Bottom line is; if its well sealed, it's just going to keep the water in there better :shrug:
we want to keep some kind of flotations just in case!
check post number 1! drain plugs will be installed
If you seal up the back reasonably well (and drain it often in case you didn't) it will float better than with foam and a LOT better than with water logged foam. Of course if you manage to bust open the back of the ski it won't float so well.
My Wamilton's hull is empty out back, it floats so well that it's almost nose down in the water.
My Cyclone footholds were busted out like that too, one of the guys at Wamilton's admitted it was "possible" haha.
I think that water slide picture is from the DVD "Rampt."
Is that this ski:
http://www.rd-performance.com/productTests/toolsfortricks.asp
I know Superramjet has the TWIN to that engine. If your customer wants to put it back to World Finals spec he should contact Superramjet.
Aaron
That Vinny V guy who owns that ski is some kind of crazy cage fighter ninja freak who can kill you from 20 ft with your leftover hydroturf scraps.
Wamilton was 6ft 2 until he made Vinny mad and got crushed down to his current 3ft 4.
You better do an amazing job fixing his ski or you might get your ass refoamed.
Risking your life to save the sport.....You DA MAN!
waterfreak
I had a vision!
s florida
easy there Mr "I want to kick everybodie's azz" ,cage fighting , ski destroying ,barrell rolling wanna be old fart!:splatt::chairfall:
Rickster
Matakana Menace
Please send a hi-res picture of that bird in your avatar....
:smoker:
Hi...What type of drain plug do you install?...I was thinking of doing some drain plugs in my superjet and was woundering what type to use?...Do you any pics of them?
Thanks
man, theres no reason to waste perfectly good hydroturf scraps when there are plenty of moisturizing baby wipes to use instead.
RMBC Freeride
Vintage
Pueblo, CO
I will doing another award winning turf job after the de-foaming!:Banane26:
I also did some work on the engine and tuned the carbs. This boat came from Colorado, so some things had to be changed to adjust to sea level.
it belongs to mr, "STEVES SKI RUNS! STEVES SKI RUNS! STEVES SKI RUNS!"
we call him vince.
hes scooby's real father.
Wow, I know vince, aka, scooby's real father, aka ninja freak, aka v1freestyle.... cool. Did you move to Florida, or just your ski?
-Neil
Rickster
Matakana Menace
-Neil
he comes here about once a year or so to harass, ridicule, ride with, keep us in check.
.... im almost getting used to him.
:haha:
