FX-1 Who has a Coffman Dry pipe in there FX1???
tshank123
Yo hablo ingles
Vegas
I'm not sure who, but I've seen a pic of it. I remember he had to shave down the lip on the engine compartment and dent the side of it to get it in there.
dirkdiggler
WI
Here is a picture to give you an idea
Coffman pipe
OK, it is going in much easier than I thought it would. I did have to cut a bit off the lip in 2 places but it is still really strong there and the hood seal is just fine. Here are some pics. Mike
Coffman pipe
Yes, It took me a few days to decide if I really wanted to cut my hull or not. After I talked to another guy that did his I decided to just do it. If it didnt work I can always repair it. Mike
rkm
McCall, ID
Itll probably need dents and the hull cut. The gas tank will rub a bit unless you put a SJ tank in, that helps it clear.
To get mine to run good, I had to run it as cold as possible with a 145 jet in the stinger. Wont run above 5000 feet like this though unless you pinch the stinger
LIVE2RIDE Powersports
Live & Die 2 Ride
WorldWide
Do these have more low end then a coffman sizzler? I have the option to buy one of these, but heard it for top end and not worth the hassle.
