Could this be a bad starter?
I finally cleaned up enough to have room to work on my fx1 so now I'm back to diagnosing the problems. When I try to start the ski it just makes a loud click but doesn't turn over at all. It started turning over once but it was way slower then normal. Last time it ran it felt like it was running on 1/4 power. That may have been bad plugs though.
What kind of preventative maintenence should I do while I'm at it? I'm going to try and replace the battery cables and starter cables. Anything else?
SJBrit
Extraordinary Alien
Bradenton, FL
Dumb question: is your battery charged? Also, have you tried turning the motor over by hand to check that it is spinning free? Remove the plugs and reach down to spin the coupler to check. If you have a good battery and a clean spinning motor then i would check the starter cable connections before you replace them. A bad connection can cause starting issues.
OCD Solutions
Rentz, GA
The coupler is located at the rear of your engine and is just under the rounded plastic cover. The SJ one's are held on by 2 bolts into the bedplate corners and a rubber retainer at the back.
ger87410
How did I get here?
Fort Worth
Forget the battery being charged...
Try swapping with a known good battery. That's the only way to rule out the battery. Can you short the starter straight to the battery on those skis like you can with a 550?
I pulled the intake grate and tried to spin the shaft but couldn't so I pulled most of the pump and I'm about try to start it. I did discover it has a solas 19-25 prop which I didn't know. I swapped the battery with another and as far as I know both were good but neither have been used in a while. One was over 14 volts though
You have to spin the motor at the coupler, only way to get good leverage on it.
Also, your cables could be bad causing you not to get enough AMPS to spin the starter.
Can I jump the batt straight to the starter safely? If so how?
I remover the pump and shaft and still not starting.
You could hook a wire straight to the starter but do not have the battery grounded. Then touch the ground to the block and see if the starter turns over under load. Having the starter on a bench does not give it any load, it may spin like crazy but die when you install it back.
i couldnt figure out where to hook up to the starter so i pulled the flywheel cover and tried spinning the flywheel and couldnt get it to move at all. Should it be that hard to turn or can i pretty much assume the motor is seized? If the motor is seized what should i look for? Im planning on pulling it the next chance i can and i suppose disassembling it but i dont know what exactly to watch out for as ive never taken a motor apart before.
SJBrit
Extraordinary Alien
Bradenton, FL
Did you take the plugs out first? You won't be able to spin it with them in, and it should turn pretty easily with them out. Get a wrench or socket on the flywheel bolt - that's an easy way to turn it.
i didnt have the plugs completly out but they were loose enough to where i dont think it would have been an issue. Ill try again later. I ended up breaking the bolt free before it actually spun though.
SJBrit
Extraordinary Alien
Bradenton, FL
Pump out, plugs out and the flywheel bolt broke free trying to turn the motor? Sorry to say that that doesn't sound good at all - you're looking at a full teardown at this point. When was the last tome this motor was running? You said it felt like it had low power?
It was running around October but then wouldn't start so it has been parked since. The last day I rode I barely had enough power to get on plane. Then it started having trouble starting. It would either click or turn over very slowly. If I have to tear it down would it be wise to mod it a little or just rebuild it? It's an fx1 so the pump is currently a limiting factor.
ouch. you need to repair that thing most likely. pull the head and cylinder..
how? im fairly sure i know how to pull the head but once i get past there im not so certain. Also where can i find the torque specs for anything i will need to disassemble? I assume this info is out there somewhere already but im not so sure as to what i should search for. This will be the first time ive done anything w/ the motor aside from stuff with the carbs so its new territory for me.
