Pricing Question (96 SJ)
Windsor
Looking at a completely Stock 1996 RN SJ. It appears to be quite clean. Ask price is $2000. What should I be looking for? Owner is the 2nd owner and owned it for quite a while, but does not know much about it. Thoughts/comments?
Thanks.
Sospikey
Trying to get upside down
Sweden
Thanks.
Does it run? What compression does it have? Any oxidation (as in salt water use)? Is the hull intact? Any idea of number of hours on it?
There is a guide either here or on sbt for buying a used ski, do a search.
2000 sounds fair, assuming it is in decent shape. figure a 2000 goes for about $3k, so a 1996 could go from 1500-2500 depending on the condition, mods, etc. If you could get it for 1800, that would be decent. All the questions above will factor the price. i love buyin from 40 yr old dads who weren't really into the standup. sadly, i don't love buying a used surf ski that has been backflipped 100x.
Windsor
The owner says no cracks in the hull, freshwater use only and no idea on compression. I have yet to see it but will hopefully go take a look this wknd.
He has no idea of the hours and says he is tentative to start it in the cold weather (which worries me).
Thanks for the guidance.
chriselmore_1
high on resin
san jose ca
i wouldnt pay $2000 for a stock 96 sj that wont fire right up. especially in the winter. bring a compression guage when you check it out. even a cheap one thats not accurate if you have too. just make sure the numbers are the same or pretty close. iwould maybe pay $1500. you would be better off paying a little extra for a sj with some goodies already on it that'll fire right up
Windsor
Opted to take a pass. Too many question marks with this ski. I am in no rush as there is snow on the ground here, so I still have time to shop around. The hunt continues. Thanks for the help
