The lines of the tray look sweet. Are you going to widen the tray at all?
Whoa! I thought you was just trying to remove a pump shoe! Great work on the sides. Where did your trick stainless pole mount reinforcement go?
I think the snorkel might collapse when it starts sucking lots of air. Worth a try though, worst case is you have to add holes to your hood.
Thanks, I hope they work. Never used any before.Nice footholds!
Well I need help. Not sure if I want to put a scupper or one-way in after reading how bad the leak. I do like to stop and chat to fellow boaters often. I do a lot of turn sub and would do more if I did not have to wait for water to be pumped out. Trent what was that link you sent me not long ago. Its what you said you were doing to yours?
Well I need help. Not sure if I want to put a scupper or one-way in after reading how bad the leak. I do like to stop and chat to fellow boaters often. I do a lot of turn sub and would do more if I did not have to wait for water to be pumped out. Trent what was that link you sent me not long ago. Its what you said you were doing to yours?[/QUOTE]
http://www.pwctoday.com/f12/cheap-scupper-build-thread-154058.html
I thought about it, but not sure if i'll follow through right now, I need a motor. Its cheap enough though. Since your refoaming it would be an ideal time and you could seal the plumbing up well. If you scupper/one way and run your intake through the pole I doubt you would have much more water issues.
Check this out if your scared of a leaking scupper http://www.x-h2o.com/threads/58878. Supposed to not leak.
I like how you widened those holds at the back. I have 2 other skis that need holds, I may try making some.
From my own experience I would tell you not to use those particular one-ways. Hope its not too late. The one's that seem to work well are the square body versions. I used one of those round ones on my sj and it leaked like crazy. Maybe I just got a bad one, dunno.
I think i need a little commission on that find:fest06:.
