SXR Base gasket
cmeripper26
Ripper26
Connecticut
If your gonna drop dome sizes in your head the best way to get then most out of dropping sizes is running an aftermarket base gasket. TBM makes a good copper one i believe. Either way if you decide to just drop ur domes ur still boosting your compression a bit.
Scorn800
Ride for life
North NJ
You can NOT run drop down domes without the correct thicknest of base gasket.
Call Kommander and talk to them about it
The ADA domes domes I have seen have squish bands that are too narrow for low-down torque, you can get them custom made from them with wider squish(I did). I think Komm Ind has domes with the wide squish
I ll give a call. Im running a 28cc domes now and my compression is 190 Do I need to change dome size when I order new dropped domes or will the compression stay the same. Im running pump gas 92-93 and a wet pipe. What the differance if I put a 040 or 060 as far as perforrnance? Hows it gonna run? Thanks
