- maryland
im installing a msd enhancer on a 07 superjet. But i start taking all the screws off the sealed box but the one mounting bracket seems to be put in with epoxy? anyone else have this problem??
Can you get the stud to twist at all :beerchug:back and forth with a pair of vise grip's ?
No...
Soak them in penetrating oil to loosen up the corrosion that built up between the stainless studs and aluminum e-box...
Then use a Bifing hammer....
I had to take off my dash, and remove the e-box and brackets as one. Worked on 'em outside the ski. Maybe easier.
