Pretty sure the 2 tuning screws was only on some and not all.
Figured the later ones went to the newer style, but have never confirmed it.
I've read on here that Factory never made a 'B' pipe for a Kawi, but I don't know.
People tend to call the 2 screw one an 'A' pipe. I've only ever seen them on Kawis and mix and match setups. Though it wouldn't surprise me if some older squares had the 2 screw head pipe too.
Wonder if Factory would give me a break down of what was made when if I called?
*Edit* Blowsion sells an adapter plate so you can use a 'B' pipe on your SX-R. If they made a 'B' pipe for the SX-R, why would they need a conversion plate?
http://www.blowsion.com/detail.asp?PRODUCT_ID=01-01-060
Blowsion also sells an SX-R wet pipe, and the SX/SXI pipe, but only call the Yamaha pipe a 'B' pipe.
