- Palm Beach, Fl
So i have been building this ski for over 5 months now. First off i started with a 1990 square with a stock motor and minor pump mod's. I have been building this ski at Wamiltons Customs. If it was not for Wamilton, Kevin Collins, 701 Superjet, Ed at E3trailers.com,Munkie and every one else i would definately not be this far!
Heres a list of my modified parts i have so far.
-08 CompleteLight Weight Wammer Hull with pre 08 bottom, Carbon Reinforced With Graphic Kit From Previous Owner
-62T Cases Ported and Epoxied
-My Old 61X Cylinder Ported and Bored over
-Pro X Pistons
-Wammer Mod Factory Pipe With Carbon Chamber
-MSD Enhancer
-OEM 44 Carbs With Ported Manifold
-Wamiltons Ride Plate
-Wamiltons Intake Grate
-Wamiltons Turn Plate
-ADA Girdled Head Kit
-ADA 33cc Domes
-Wamiltons Stubbie Cone
-Wamiltons Hood Latch
-Straight Bars
-RRP Lowered Handle Pole Bracket
-Skat 12/17 Prop
-Wamiltons Carbon Water Box
-Clear Throttle
-Wamiltons Mat Kit
-Turfed OEM Chin Pad
-Aftermarket Reed Pedals
-Wamiltons Hood Straps
New OEM parts i have had to get so far
-Stock 96+ Exhaust Hose
-96+ Handle Pole "just had it painted black!"
-Pole Bolt
-Starter
-Gaskets for motor
-Bearings for motor
-Rebuild pump
-96+ Mid shaft assembly
-Rebuild mid shaft assembly
-Hood Seal
Let me know what you all think! More pics to come.
-Pro X Pistons
-MSD Enhancer
-ADA 33cc Domes
-Straight Bars
-Skat 12/17 Prop
-Clear Throttle
-Wamiltons Mat Kit
-Pole Bolt
-Starter
-Gaskets for motor
-Bearings for motor
-Rebuild pump
-Hood Seal
