What are you guys running over stock carb jetting, n/s, spring ....or no change? Thanks.
JeffX2&SX Sep 22, 2009 #1 What are you guys running over stock carb jetting, n/s, spring ....or no change? Thanks.
cmeripper26 Ripper26 Location Connecticut Sep 22, 2009 #2 The jets should have came with the pipe when u bought it.
rollin5150 Location Idaho Sep 23, 2009 #3 Here in AZ I am running a 150 high for summer 152.5 for winter and 80 low. I have 2.0 N/S with the black spring.
Proformance1 Liquid Insanity Site Supporter Vendor Account Location New York Crew Sep 23, 2009 #4 152.5 and 80 with 80 gram or black spring 2.0 needle and seat spring and needle/seat are stock
rollin5150 Location Idaho Sep 23, 2009 #5 Proformance1 said: 152.5 and 80 with 80 gram or black spring 2.0 needle and seat spring and needle/seat are stock Click to expand... Stock seat is 1.5
Proformance1 Liquid Insanity Site Supporter Vendor Account Location New York Crew Sep 23, 2009 #6 good to know, I never checked, but was told they were 2.0 stock
gorilla There's Always A Light At The End Of The Tunnel !! Location Lost Wages NV Sep 25, 2009 #7 ok, what's the pop-off pressure on that setup ??? 15-18-20 lb's ??? get wet gorilla
rollin5150 Location Idaho Sep 25, 2009 #8 gorilla said: ok, what's the pop-off pressure on that setup ??? 15-18-20 lb's ??? get wet gorilla Click to expand... Right around 21 psi
Shonuff I've got the glow Site Supporter Location Memphis Sep 27, 2009 #10 M 152.5 P 80 N&S 1.8 S 80g Last edited: Oct 1, 2009
Shonuff I've got the glow Site Supporter Location Memphis Oct 1, 2009 #12 Millertime said: you sure that is not P 80 M152.5 ???? Click to expand... Ha! Good point. My bad.
