Flash-FX
No Square..No Round..FX-1
- South Jersey Shore
That would be FX-6.9boy and I :sneaky:
You guys are too cool!
If you go the glass work route you won't be facing welding mods again when your wear ring corrodes.....just a long term thought.....and maybe only a saltwater concern. I know my stock FX wear ring only lasts a couple seasons before it's junk!
Here is a visual look at why the rear needs shims even though you would think it would not using a bigger pump. The FX pump is on the right. They are both sitting level and the SJ Pump actually needs to go up about 2mm to center with the FX Nozzle. My FX also had about 2 or 3mm of shim on the original pump which gets me to the 5 I have shimmed it at to center.
Also note the large insulators on the FX pump which raise the pump up quite a bit.
Nice pix...good topic. All I'm saying is double check your driveshaft centering (from the spline end to the tail end), if the shims are needed you have to use them. All boats are a little different.
Here are a few pix of what Blowsions answer is for the FX/144mm pump mod, "Bolt in". They cut off the forward mounting tabs and re-weld them (I think this is what Special FX was referring to with the wear ring life span/replacement, you can't use a off the shelf Yamaha part). The rear tabs were re-located also. For the guys that I've seen using this pump, it still required lots of grinding/glass work. The performance is worth it. :fing02:
Who are "Texas amigos Brian and Elmer" that developed this mod for Blowsion?
Nope Finished the pump install with the stock pump shoe and road it all last year. I am headed to the LSFR this weekend with a newly installed 144 aluminum pump shoe and Hooker impeller. The pump shoe was harder than the pump itself.
Water tested is 2 days ago. It rocks. I think the Hooker pumped up the low end hookup from the 14-18 I had and the larger pump shoe has made the top end feel even faster but that was just my seat of the pants opinion. I will have to get another ski out against it to compare.
No shaft or mid shaft issues and it was mostly surf riding all last summer.
Show us the intake grate.I just finished my yamaha 144 conversion. It was a lot of work but it completely changed the ski for the better. I made it so that any 144 pump can bolt right up. The next step is to create a good intake grate. So far I'm runing a rigged up/getto setup but it works ok. I run a 9/15 Hooker, PSI pipe, and single carb with milled head. It's amazing. PM me if you want some pics.
the blowsion unit is the same as the bonzai bob conversion....
the pump will drop right in, but glasswork is needed to enlarge the intake cavity..
Idok, Ewok, and Butti got me talked into doing the 140mm on my current build. I've just aquired all of the parts except the bearing. They all claim it's a ton easier and a ton better.
Can't wait to do it.
