D-Roc
I forgot!
- Dirty River Rider
does it matter which way the single carb is installed? fuel pump close to the hull so you can use the stock kawi cable keeper, or if you have the aftermarket one would it matter if it had the fuel pump side of the carb close to the motorl, so the throttle cable has more length? i had it setup so that the pump side was to the motor but turned it around today and haven't tried it. just wondering if there is a true way to have it.
