- Granbury, TX
Hey all, I have a '91 SJ with a stock 650. Only mods on it currently are a ProTec F-series pipe (stainless chamber) along with the carb re-jetted with ProTec's specific jet kit (I think its a 135H 120L?). Stock F/A with only one screen installed. Prop is a solas 14.5x18.5. I have also installed a trimpot on the rev-limiter.
Last weekend it started falling off on the top end so I richened it up and started reading plugs. They were practically white... richening was doing nothing.
Last night I blew out the fuel pickup, cleaned out the clean fuel filter, blew out the fuel line and eliminated my fuel selector. SO right now, fuel comes from the reserve pickup to the fuel filter, straight into the carb.
I also took apart the carb, jets were clean, internal filter was clean, and I blew out the passages with carb cleaner and compressed air.
This morning I tried it out. Same thing, I went all the way to 2 3/4 turns out on my high speed screw and the plugs are still white. The low end is at 1 3/4 turns out. I checked all my cooling hoses, blew them out and verified the pump was flowing water through them. Right now the motor seems to be running way to hot, the manifold sizzles a bit when you drip water on it and the head is hotter than it should be (by touch). I don't know what else to check at this point.... Any ideas? I also haven't been able to find much info on this ProTec pipe setup that I am running. It feels to me like I should have way more grunt and top end (I know its a 650). To me it feels like a bone stock 650. Again, any input, tips, or suggestions would be greatly appreciated. Thanks in advance.
EDIT: I forgot to mention, where I have been riding lately is shallow and sandy. Is it possible my cooling passages are filled with sand? Maybe enough to prevent proper cooling but not enough to impede coolant flow? Just wondering....
