Charging
FlightPlanDan
Don'tTrustAfartAfter50
I've done a search on this but no specific answer yet.
Is it possible to damage your CDI, or anything else, by charging the battery while it's still hooked up? If the lanyard is in? I've heard conflicting thoughts on this issue.
accbr
addicted
Lexington, KY
I used to have a zip tie wrapped around the my start stop switch, so I didn't have to use a lanyard. I charged it like that all the time, and never had a problem.
Idaho
Not to familiar with the superjet electronics but I hook my Battery Tender Jr to my batter after every ride. Yes, the battery stays in the ski and is hooked up. Same thing with my Pro 785. Never had an issue.
#ZERO
Beach Bum
Florida - U.S.A.
I seriously doubt you could damage a CDI by leaving the battery connected but it might be possible if you hooked up the polarity of the battery the wrong way.
The fuse will pop if you do that.
If you do not have a fuse, the voltage regulator will pop.
No CDI damage.
