ada racing head and carbon tech reeds and blowsion flywheel
what do you guys think about the ada head with 35cc domes?
what do you think about the reeds?any more power?
does the flywheel really help bottomend alot?
i have a stock 94 superjet so could you guys help me out aout these parts?
junkyardj
┌∩┐(◣_◢)┌∩┐
imho i would go for the flywheel first if $$ is a issue then reeds.. i dont think you'll notice much if anything from the head unless you bump up the comp.
Head, pipe, prop and enhancer if you have the coin.
ada head with 35 cc domes 344$ shipped to your door
factory pipe if you can swing it 697$ shipped to your door
get a prop will run about 2 bills
enhancer 177$ shipped to your door.
you will be more then happy with these 4 mods
I would leave the stock reeds alone,
Flywheel would be a good choice if you have another 65$ to spend after all that.
The above is all I am doing to my 09 as far as go fast parts are concerned. I have other stuff for hull mods
Your compression should be about 155
